주요 콘텐츠로 건너뛰기
Sony Vaio PCG-41216L Hard Drive Replacement
필요한 것
  1. Sony Vaio PCG-41216L Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 Sony Vaio PCG-41216L Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Flip the laptop over to begin the process.
    • Make sure the laptop is turned off and unplugged from the power cable.
  2. Sony Vaio PCG-41216L Hard Drive Replacement: 2 단계, 이미지 1/3 Sony Vaio PCG-41216L Hard Drive Replacement: 2 단계, 이미지 2/3 Sony Vaio PCG-41216L Hard Drive Replacement: 2 단계, 이미지 3/3
    • Remove the two 7mm Phillips #1 screws holding the battery cover.
  3. Sony Vaio PCG-41216L Hard Drive Replacement: 3 단계, 이미지 1/3 Sony Vaio PCG-41216L Hard Drive Replacement: 3 단계, 이미지 2/3 Sony Vaio PCG-41216L Hard Drive Replacement: 3 단계, 이미지 3/3
    • Peel off the ribbon cable, starting at the top by the wifi card.
  4. Sony Vaio PCG-41216L Hard Drive Replacement: 4 단계, 이미지 1/3 Sony Vaio PCG-41216L Hard Drive Replacement: 4 단계, 이미지 2/3 Sony Vaio PCG-41216L Hard Drive Replacement: 4 단계, 이미지 3/3
    • Remove all of the 7mm Phillips #1 casing screws around the hard drive.
  5. Sony Vaio PCG-41216L Hard Drive Replacement: 5 단계, 이미지 1/1
    • Pull the hard drive out, then remove the 3mm Phillips screws that connect the hard drive to the casing.
결론
john nunnelee
회원 가입일: 01/10/19
174 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 49
전체 시간: 2,259
