주요 콘텐츠로 건너뛰기
Sony Vaio PCG-41216L Network Card Replacement
필요한 것
  1. Sony Vaio PCG-41216L Network Card Replacement, Network Card: 1 단계, 이미지 1/2 Sony Vaio PCG-41216L Network Card Replacement, Network Card: 1 단계, 이미지 2/2
    • Flip the laptop over to begin the process.
    • Make sure the laptop is turned off and unplugged from the power cable.
  2. Sony Vaio PCG-41216L Network Card Replacement: 2 단계, 이미지 1/3 Sony Vaio PCG-41216L Network Card Replacement: 2 단계, 이미지 2/3 Sony Vaio PCG-41216L Network Card Replacement: 2 단계, 이미지 3/3
    • Remove the two 7mm Phillips #1 screws holding the battery cover.
  3. Sony Vaio PCG-41216L Network Card Replacement: 3 단계, 이미지 1/3 Sony Vaio PCG-41216L Network Card Replacement: 3 단계, 이미지 2/3 Sony Vaio PCG-41216L Network Card Replacement: 3 단계, 이미지 3/3
    • Locate the networking card above the hard drive and next to the RAM.
    • Carefully pop out the two connection cables from the networking card.
  4. Sony Vaio PCG-41216L Network Card Replacement: 4 단계, 이미지 1/3 Sony Vaio PCG-41216L Network Card Replacement: 4 단계, 이미지 2/3 Sony Vaio PCG-41216L Network Card Replacement: 4 단계, 이미지 3/3
    • Remove the black tape to uncover the screw underneath.
    • Remove the 3mm Phillips head screw.
    • When loosening the screw, the network card will automatically lift itself to a diagonal position. This is normal.
  5. Sony Vaio PCG-41216L Network Card Replacement: 5 단계, 이미지 1/2 Sony Vaio PCG-41216L Network Card Replacement: 5 단계, 이미지 2/2
    • Pull the network card straight out in the direction it is resting in.
    • Reinsert the new network card diagonally and into the same position as the previous one.
    • To screw the new network card back into place, you will need to push the network card back down onto the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Elmar Charoensaengsanga
회원 가입일: 03/15/18
384 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 583
