소개
If noise sounds distorted or the headphone jack does not pick up your sound device, the AUX Board may need to be replaced. Before starting this guide, try to blow dust out to see if the issue is resolved. Make sure to have a secure place to put the screws after they have been removed.
필요한 것
Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
Remove seven 3mm Phillips #0 screws from the bottom of the computer.
Remove eight 5mm Phillips #0 screws.
다른 2명이 해당 안내서를 완성하였습니다.
