주요 콘텐츠로 건너뛰기
Sony Vaio PCG-4121GL Battery Replacement
필요한 것
  1. Sony Vaio PCG-4121GL Battery Replacement, Battery: 1 단계, 이미지 1/2 Sony Vaio PCG-4121GL Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
  2. Sony Vaio PCG-4121GL Battery Replacement: 2 단계, 이미지 1/3 Sony Vaio PCG-4121GL Battery Replacement: 2 단계, 이미지 2/3 Sony Vaio PCG-4121GL Battery Replacement: 2 단계, 이미지 3/3
    • Pull the bottom plate towards yourself until it unhinges fully.
    • Once the plate is free from the backing remove it completely.
  3. Sony Vaio PCG-4121GL Battery Replacement: 3 단계, 이미지 1/1
    • Look for the blue tab that is located to the bottom left of the battery.
  4. Sony Vaio PCG-4121GL Battery Replacement: 4 단계, 이미지 1/3 Sony Vaio PCG-4121GL Battery Replacement: 4 단계, 이미지 2/3 Sony Vaio PCG-4121GL Battery Replacement: 4 단계, 이미지 3/3
    • Pull the blue tab towards yourself until you hear a click.
    • Once the blue tab is released, pull up on the battery.
    • Once the battery can move freely, take it out completely.
    • It may be helpful to have a spudger to make it easier to release the blue tab.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
McKinley Hubred
회원 가입일: 01/24/19
127 평판
안내서 1개 작성함
Cal Poly, Team S2-G2, White Winter 2019 Cal Poly, Team S2-G2, White Winter 2019 회원
CPSU-WHITE-W19S2G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 51
전체 시간: 2,814
