주요 콘텐츠로 건너뛰기
Sony Vaio PCG-4121GL SD Card Board Replacement
필요한 것
  1. Sony Vaio PCG-4121GL SD Card Board Replacement, Battery: 1 단계, 이미지 1/2 Sony Vaio PCG-4121GL SD Card Board Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
  2. Sony Vaio PCG-4121GL SD Card Board Replacement: 2 단계, 이미지 1/3 Sony Vaio PCG-4121GL SD Card Board Replacement: 2 단계, 이미지 2/3 Sony Vaio PCG-4121GL SD Card Board Replacement: 2 단계, 이미지 3/3
    • Pull the bottom plate towards yourself until it unhinges fully.
    • Once the plate is free from the backing remove it completely.
  3. Sony Vaio PCG-4121GL SD Card Board Replacement: 3 단계, 이미지 1/1
    • Look for the blue tab that is located to the bottom left of the battery.
  4. Sony Vaio PCG-4121GL SD Card Board Replacement: 4 단계, 이미지 1/3 Sony Vaio PCG-4121GL SD Card Board Replacement: 4 단계, 이미지 2/3 Sony Vaio PCG-4121GL SD Card Board Replacement: 4 단계, 이미지 3/3
    • Pull the blue tab towards yourself until you hear a click.
    • Once the blue tab is released, pull up on the battery.
    • Once the battery can move freely, take it out completely.
    • It may be helpful to have a spudger to make it easier to release the blue tab.
  5. Sony Vaio PCG-4121GL SD Card Board Replacement, SD Card Board: 5 단계, 이미지 1/2 Sony Vaio PCG-4121GL SD Card Board Replacement, SD Card Board: 5 단계, 이미지 2/2
    • Remove seven 3mm Phillips #0 screws from the bottom of the computer.
    • Remove eight 5mm Phillips #0 screws.
  6. Sony Vaio PCG-4121GL SD Card Board Replacement: 6 단계, 이미지 1/3 Sony Vaio PCG-4121GL SD Card Board Replacement: 6 단계, 이미지 2/3 Sony Vaio PCG-4121GL SD Card Board Replacement: 6 단계, 이미지 3/3
    • Carefully remove the disk drive from its compartment.
  7. Sony Vaio PCG-4121GL SD Card Board Replacement: 7 단계, 이미지 1/2 Sony Vaio PCG-4121GL SD Card Board Replacement: 7 단계, 이미지 2/2
    • Remove the three 2mm Phillips #00 screws located on the top right edge.
  8. Sony Vaio PCG-4121GL SD Card Board Replacement: 8 단계, 이미지 1/2 Sony Vaio PCG-4121GL SD Card Board Replacement: 8 단계, 이미지 2/2
    • Gently pull apart the top and bottom plastic bodies.
    • Carefully remove the cable connectors.
    • Slowly detach bottom component to avoid tearing wires/connectors.
  9. Sony Vaio PCG-4121GL SD Card Board Replacement: 9 단계, 이미지 1/3 Sony Vaio PCG-4121GL SD Card Board Replacement: 9 단계, 이미지 2/3 Sony Vaio PCG-4121GL SD Card Board Replacement: 9 단계, 이미지 3/3
    • Pull apart your device and set aside the screen of your laptop.
    • Locate the SD Card Board in the bottom left of the computer body.
  10. Sony Vaio PCG-4121GL SD Card Board Replacement: 10 단계, 이미지 1/2 Sony Vaio PCG-4121GL SD Card Board Replacement: 10 단계, 이미지 2/2
    • Remove the cables from their connectors.
    • Do not apply too much force to the cable connectors or they may tear.
  11. Sony Vaio PCG-4121GL SD Card Board Replacement: 11 단계, 이미지 1/2 Sony Vaio PCG-4121GL SD Card Board Replacement: 11 단계, 이미지 2/2
    • Lightly press down on the bottom left corner of the plastic frame.
    • Pull SD Board out towards you once it feels loose.
    • Once the SD Board is free from the plastic, remove completely
    • The SD Card slot is shown.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bryce McNeil
회원 가입일: 01/24/19
391 평판
안내서 1개 작성함
Cal Poly, Team S2-G2, White Winter 2019 Cal Poly, Team S2-G2, White Winter 2019 회원
CPSU-WHITE-W19S2G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 30
전체 시간: 930
