주요 콘텐츠로 건너뛰기
Sony Vaio PCG-4121GL Wifi Board Replacement
필요한 것
  1. Sony Vaio PCG-4121GL Wifi Board Replacement, Battery: 1 단계, 이미지 1/2 Sony Vaio PCG-4121GL Wifi Board Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
  2. Sony Vaio PCG-4121GL Wifi Board Replacement: 2 단계, 이미지 1/3 Sony Vaio PCG-4121GL Wifi Board Replacement: 2 단계, 이미지 2/3 Sony Vaio PCG-4121GL Wifi Board Replacement: 2 단계, 이미지 3/3
    • Pull the bottom plate towards yourself until it unhinges fully.
    • Once the plate is free from the backing remove it completely.
  3. Sony Vaio PCG-4121GL Wifi Board Replacement: 3 단계, 이미지 1/1
    • Look for the blue tab that is located to the bottom left of the battery.
  4. Sony Vaio PCG-4121GL Wifi Board Replacement: 4 단계, 이미지 1/3 Sony Vaio PCG-4121GL Wifi Board Replacement: 4 단계, 이미지 2/3 Sony Vaio PCG-4121GL Wifi Board Replacement: 4 단계, 이미지 3/3
    • Pull the blue tab towards yourself until you hear a click.
    • Once the blue tab is released, pull up on the battery.
    • Once the battery can move freely, take it out completely.
    • It may be helpful to have a spudger to make it easier to release the blue tab.
  5. Sony Vaio PCG-4121GL Wifi Board Replacement, WiFi Board: 5 단계, 이미지 1/2 Sony Vaio PCG-4121GL Wifi Board Replacement, WiFi Board: 5 단계, 이미지 2/2
    • Lift up the two golden knobs on the left side of the WiFi board.
    • Remove the single 3mm Phillips #0 screw located on the WiFi board to the top left of the battery compartment.
  6. Sony Vaio PCG-4121GL Wifi Board Replacement: 6 단계, 이미지 1/2 Sony Vaio PCG-4121GL Wifi Board Replacement: 6 단계, 이미지 2/2
    • Once the screw and the golden knobs have been disconnected, pull the WiFi board out to the left.
    • Once the WiFi board is free from the device, remove completely.
결론
Miguel Camarena
회원 가입일: 01/24/19
367 평판
안내서 3개 작성하였습니다
Cal Poly, Team S2-G2, White Winter 2019 Cal Poly, Team S2-G2, White Winter 2019 회원
CPSU-WHITE-W19S2G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 15
전체 시간: 623
