주요 콘텐츠로 건너뛰기
Sony Vaio PCG-4G1L Plastic Casing Replacement
필요한 것
  1. Sony Vaio PCG-4G1L Plastic Casing Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the computer and disconnect the charging cable.
    • Failing to unplug the cable can result in electric shock.
  2. Sony Vaio PCG-4G1L Plastic Casing Replacement: 2 단계, 이미지 1/2 Sony Vaio PCG-4G1L Plastic Casing Replacement: 2 단계, 이미지 2/2
    • Slide battery release toggle switch towards the "RELEASE" print.
  3. Sony Vaio PCG-4G1L Plastic Casing Replacement: 3 단계, 이미지 1/3 Sony Vaio PCG-4G1L Plastic Casing Replacement: 3 단계, 이미지 2/3 Sony Vaio PCG-4G1L Plastic Casing Replacement: 3 단계, 이미지 3/3
    • Apply pressure with your thumb on the grip.
    • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
  4. Sony Vaio PCG-4G1L Plastic Casing Replacement, Keyboard: 4 단계, 이미지 1/2 Sony Vaio PCG-4G1L Plastic Casing Replacement, Keyboard: 4 단계, 이미지 2/2
    • Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
  5. Sony Vaio PCG-4G1L Plastic Casing Replacement: 5 단계, 이미지 1/2 Sony Vaio PCG-4G1L Plastic Casing Replacement: 5 단계, 이미지 2/2
    • Be sure to pry the plastic opening tool under the keyboard, rather than under the keys. Otherwise, some keys could get harmed.
    • While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
  6. Sony Vaio PCG-4G1L Plastic Casing Replacement: 6 단계, 이미지 1/3 Sony Vaio PCG-4G1L Plastic Casing Replacement: 6 단계, 이미지 2/3 Sony Vaio PCG-4G1L Plastic Casing Replacement: 6 단계, 이미지 3/3
    • Do not pull the keyboard too far away, as a ribbon cable is still attached. Failing to do so can cause damage to the ribbon cable or the connector.
    • Use the plastic opening tool to release the clamp.
    • Using slight pressure, remove the ribbon cable with your fingers.
  7. Sony Vaio PCG-4G1L Plastic Casing Replacement, Network Antenna: 7 단계, 이미지 1/1
    • Swivel the Network Antenna up so that it points upward.
  8. Sony Vaio PCG-4G1L Plastic Casing Replacement: 8 단계, 이미지 1/2 Sony Vaio PCG-4G1L Plastic Casing Replacement: 8 단계, 이미지 2/2
    • Pinch thumb and index finger at the Network Antenna's base.
    • Make sure not to bend the Network Antenna. Failing to do so can cause damage to the antenna.
    • Pull the Network Antenna off.
  9. Sony Vaio PCG-4G1L Plastic Casing Replacement, Plastic Casing: 9 단계, 이미지 1/2 Sony Vaio PCG-4G1L Plastic Casing Replacement, Plastic Casing: 9 단계, 이미지 2/2
    • Remove seven 5 mm Phillips #1 pan head screws with a Bit Driver, using a Phillips PH1 bit.
  10. Sony Vaio PCG-4G1L Plastic Casing Replacement: 10 단계, 이미지 1/2 Sony Vaio PCG-4G1L Plastic Casing Replacement: 10 단계, 이미지 2/2
    • Remove one 7 mm Phillips #1 Pan Head Screw by using a Bit Driver with Phillips PH1 bit.
  11. Sony Vaio PCG-4G1L Plastic Casing Replacement: 11 단계, 이미지 1/2 Sony Vaio PCG-4G1L Plastic Casing Replacement: 11 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Disconnect the cable by using the precision tweezers.
    • Slowly pry out the ribbon cable by using the plastic opening tool.
  12. Sony Vaio PCG-4G1L Plastic Casing Replacement: 12 단계, 이미지 1/1
    • Do not pull the plastic cover too far away, as a ribbon cable is still attached. Failing to do so can cause damage to ribbon cable or the connector.
    • Remove the plastic cover by inserting the plastic opening tool around the edge.
  13. Sony Vaio PCG-4G1L Plastic Casing Replacement: 13 단계, 이미지 1/2 Sony Vaio PCG-4G1L Plastic Casing Replacement: 13 단계, 이미지 2/2
    • Disconnect the ribbon cable by pulling straight up with your fingers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cole Collins
회원 가입일: 10/04/16
175 평판
안내서 4개 작성하였습니다
USF Tampa, Team 2-3, Cagle Fall 2016 USF Tampa, Team 2-3, Cagle Fall 2016 회원
USFT-CAGLE-F16S2G3
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 833
