소개
If the LCD Display Screen is black, cracked, or has colored lines running through it when the computer is on, the screen is broken. Follow these instructions on how to install a screen
부품
부품은 필요하지 않습니다.
  1. Place the computer on a flat surface with the top facing up. Open the screen.
    • Place the computer on a flat surface with the top facing up.
    • Open the screen.
  2. Locate the rubber screw caps at the two bottom corners of the screen. Use your finger to remove the rubber screw caps. Use your finger to remove the rubber screw caps.
    • Locate the rubber screw caps at the two bottom corners of the screen.
    • Use your finger to remove the rubber screw caps.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Locate the two screws, one on each bottom corner. Unscrew the screws with a Phillips head size #0 screwdriver.
    • Locate the two screws, one on each bottom corner.
    • Unscrew the screws with a Phillips head size #0 screwdriver.
    • Keep track of the screws. They are small and easy to misplace.
  5. Use a plastic opening tool to gently lift the plastic casing that borders the screen. Pop off the casing by working the tool around the outside of it. Wiggling the tool may be required. The casing could be fitted snugly.
    • Use a plastic opening tool to gently lift the plastic casing that borders the screen.
    • Pop off the casing by working the tool around the outside of it.
    • Wiggling the tool may be required. The casing could be fitted snugly.
  6. Carefully flip down the screen so it rests on the keyboard. Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection. Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
    • Carefully flip down the screen so it rests on the keyboard.
    • Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
  7. Remove the screen.
    • Remove the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Ricker
회원 가입일: 2012년 04월 04일
71 평판
안내서 1개 작성함
Cal Poly, Team 5-3, Forte Spring 2012 Cal Poly, Team 5-3, Forte Spring 2012 회원
CPSU-FORTE-S12S5G3
5 회원들
안내서 6개 작성하였습니다
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 14
전체 시간: 2,994
