주요 콘텐츠로 건너뛰기
Sony Vaio VGN-TXN25N Display Screen Replacement
필요한 것
  1. Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: 1 단계, 이미지 1/2 Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: 1 단계, 이미지 2/2
    • Place the computer on a flat surface with the top facing up.
    • Open the screen.
  2. Sony Vaio VGN-TXN25N Display Screen Replacement: 2 단계, 이미지 1/3 Sony Vaio VGN-TXN25N Display Screen Replacement: 2 단계, 이미지 2/3 Sony Vaio VGN-TXN25N Display Screen Replacement: 2 단계, 이미지 3/3
    • Locate the rubber screw caps at the two bottom corners of the screen.
    • Use your finger to remove the rubber screw caps.
  3. Sony Vaio VGN-TXN25N Display Screen Replacement: 3 단계, 이미지 1/2 Sony Vaio VGN-TXN25N Display Screen Replacement: 3 단계, 이미지 2/2
    • Locate the two screws, one on each bottom corner.
    • Unscrew the screws with a Phillips head size #0 screwdriver.
    • Keep track of the screws. They are small and easy to misplace.
  4. Sony Vaio VGN-TXN25N Display Screen Replacement: 4 단계, 이미지 1/3 Sony Vaio VGN-TXN25N Display Screen Replacement: 4 단계, 이미지 2/3 Sony Vaio VGN-TXN25N Display Screen Replacement: 4 단계, 이미지 3/3
    • Use a plastic opening tool to gently lift the plastic casing that borders the screen.
    • Pop off the casing by working the tool around the outside of it.
    • Wiggling the tool may be required. The casing could be fitted snugly.
  5. Sony Vaio VGN-TXN25N Display Screen Replacement: 5 단계, 이미지 1/3 Sony Vaio VGN-TXN25N Display Screen Replacement: 5 단계, 이미지 2/3 Sony Vaio VGN-TXN25N Display Screen Replacement: 5 단계, 이미지 3/3
    • Carefully flip down the screen so it rests on the keyboard.
    • Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
  6. Sony Vaio VGN-TXN25N Display Screen Replacement: 6 단계, 이미지 1/1
    • Remove the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Ricker
회원 가입일: 04/04/12
71 평판
안내서 1개 작성함
Cal Poly, Team 5-3, Forte Spring 2012 Cal Poly, Team 5-3, Forte Spring 2012 회원
CPSU-FORTE-S12S5G3
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 15
전체 시간: 3,598
