주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Sony Vaio PCG-4K1L Keyboard Replacement
필요한 것
  1. Sony Vaio PCG-4K1L Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Take out the screw in the center of the computer.
  2. Sony Vaio PCG-4K1L Keyboard Replacement: 2 단계, 이미지 1/1
    • Flip the computer right side up.
    • Open screen so that keyboard is visible.
  3. Sony Vaio PCG-4K1L Keyboard Replacement: 3 단계, 이미지 1/2 Sony Vaio PCG-4K1L Keyboard Replacement: 3 단계, 이미지 2/2
    • Use a plastic opening tool to gently lift the keyboard at a corner.
    • Make sure you get below the keyboard itself and not just the keys.
    • Slide the tool around the perimeter of the keyboard and it will start to lift.
  4. Sony Vaio PCG-4K1L Keyboard Replacement: 4 단계, 이미지 1/2 Sony Vaio PCG-4K1L Keyboard Replacement: 4 단계, 이미지 2/2
    • Do not pull the keyboard away from the computer. There is a ribbon cord attaching the keyboard to the computer.
    • Once the keyboard has been lifted at a few edges, lift the keyboard with both hands.
  5. Sony Vaio PCG-4K1L Keyboard Replacement: 5 단계, 이미지 1/3 Sony Vaio PCG-4K1L Keyboard Replacement: 5 단계, 이미지 2/3 Sony Vaio PCG-4K1L Keyboard Replacement: 5 단계, 이미지 3/3
    • Locate the ribbon cord behind the keyboard.
    • Locate a brown clamp attaching the keyboard to the computer.
    • Use a plastic opening tool to lift the clamp and release the cable.
    • Now the keyboard can be pulled away entirely.
결론
Austen
회원 가입일: 04/03/12
32 평판
안내서 2개 작성하였습니다
Cal Poly, Team 5-3, Forte Spring 2012 Cal Poly, Team 5-3, Forte Spring 2012 회원
CPSU-FORTE-S12S5G3
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 2,068
