소개
If your laptop is overheating you may need to replace the fan. This guide will guide you in replacing your laptop’s fan. The tools required in this process are: an iFixit opening tool, a PH0 screwdriver, and needle nose pliers.
필요한 것
Using a #0PH screwdriver, unscrew the three 4.80mm screws on the back of the device.
The screws are held into the panel by washers, they will not fall out once unscrewed.
거의 끝나갑니다!
결론
