주요 콘텐츠로 건너뛰기
Sony Vaio VPC-Y2190X Hard Drive Replacement
필요한 것
  1. Sony Vaio VPC-Y2190X Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Flip your laptop so that the bottom is facing up.
  2. Sony Vaio VPC-Y2190X Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide the “Lock” switch to the right.
    • Slide and hold the “Release” switch to the left.
  3. Sony Vaio VPC-Y2190X Hard Drive Replacement: 3 단계, 이미지 1/2 Sony Vaio VPC-Y2190X Hard Drive Replacement: 3 단계, 이미지 2/2
    • While holding the “Release” switch, lift the lip of the battery.
    • Lift the battery up and out of the laptop.
  4. Sony Vaio VPC-Y2190X Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Using a #0PH screwdriver, unscrew the three 4.80mm screws on the back of the device.
    • The screws are held into the panel by washers, they will not fall out once unscrewed.
  5. Sony Vaio VPC-Y2190X Hard Drive Replacement: 5 단계, 이미지 1/1
    • Remove the panel.
    • Use the #0PH screwdriver to remove the four 3.61mm screws.
  6. Sony Vaio VPC-Y2190X Hard Drive Replacement: 6 단계, 이미지 1/2 Sony Vaio VPC-Y2190X Hard Drive Replacement: 6 단계, 이미지 2/2
    • Carefully lift the hard drive.
    • Remove the hard drive by pulling it to the left.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kris Fleming
회원 가입일: 01/31/19
285 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 348
