주요 콘텐츠로 건너뛰기
Sony Vaio VGN-SR140E CD/DVD Drive Replacement
필요한 것
  1. Sony Vaio VGN-SR140E CD/DVD Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: 2 단계, 이미지 1/1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: 3 단계, 이미지 1/2 Sony Vaio VGN-SR140E CD/DVD Drive Replacement: 3 단계, 이미지 2/2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E CD/DVD Drive Replacement, CD/DVD Drive: 4 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to loosen all four screws. These screws are secured to their covers with retaining clips.
  5. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: 5 단계, 이미지 1/1
    • Lift the two covers with a fingernail or plastic opening tool from the sides the screws were present. Two tabs are securing the covers on the side opposite the screws.
  6. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: 6 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove both 6.5mm screws and set them aside.
  7. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: 7 단계, 이미지 1/1
    • Gently slide the CD/DVD drive out of the laptop.
결론
Jeremy
회원 가입일: 03/18/15
722 평판
안내서 4개 작성하였습니다
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015 회원
MTU-LAUER-S15S1G6
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 963
