주요 콘텐츠로 건너뛰기
Sony Vaio VGN-SR140E RAM Replacement
필요한 것
  1. Sony Vaio VGN-SR140E RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E RAM Replacement: 2 단계, 이미지 1/1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E RAM Replacement: 3 단계, 이미지 1/2 Sony Vaio VGN-SR140E RAM Replacement: 3 단계, 이미지 2/2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E RAM Replacement, RAM: 4 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove both screws. The screws are secured to the cover with retaining clips.
  5. Sony Vaio VGN-SR140E RAM Replacement: 5 단계, 이미지 1/2 Sony Vaio VGN-SR140E RAM Replacement: 5 단계, 이미지 2/2
    • Lift the thin black plastic cover to access the RAM.
  6. Sony Vaio VGN-SR140E RAM Replacement: 6 단계, 이미지 1/2 Sony Vaio VGN-SR140E RAM Replacement: 6 단계, 이미지 2/2
    • Apply light outward pressure to the locks on either side of the RAM. Rotate the RAM up slightly. Pull the RAM toward you to remove it.
  7. Sony Vaio VGN-SR140E RAM Replacement: 7 단계, 이미지 1/3 Sony Vaio VGN-SR140E RAM Replacement: 7 단계, 이미지 2/3 Sony Vaio VGN-SR140E RAM Replacement: 7 단계, 이미지 3/3
    • Using the same light outward pressure on the locks, lift the secondary RAM up and slide it away from you to remove it from its slot.
결론
Jeremy
회원 가입일: 03/18/15
722 평판
안내서 4개 작성하였습니다
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015 회원
MTU-LAUER-S15S1G6
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 469
