주요 콘텐츠로 건너뛰기
Sony Vaio VPCCW17FX Back Case
필요한 것
  1. Sony Vaio VPCCW17FX Back Case, Back case: 1 단계, 이미지 1/1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Back Case: 2 단계, 이미지 1/3 Sony Vaio VPCCW17FX Back Case: 2 단계, 이미지 2/3 Sony Vaio VPCCW17FX Back Case: 2 단계, 이미지 3/3
    • Remove the battery by pinching the two lock tabs towards the center.
    • Next, lift up on the battery to remove it.
  3. Sony Vaio VPCCW17FX Back Case: 3 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the twenty-two 5.6 mm screws from the back of the laptop.
    • Be sure to remove all screws, including those that are typically covered by the battery.
  4. Sony Vaio VPCCW17FX Back Case: 4 단계, 이미지 1/3 Sony Vaio VPCCW17FX Back Case: 4 단계, 이미지 2/3 Sony Vaio VPCCW17FX Back Case: 4 단계, 이미지 3/3
    • Now, remove the small covers from the back of the case.
    • Using a Phillips #00 screwdriver, unscrew the three 5.6 mm screws from the covers (one screw on the RAM cover [middle] and two screws on the Hard Drive cover [bottom right]).
    • Then, lift up on and remove these covers as shown in the third image.
  5. Sony Vaio VPCCW17FX Back Case: 5 단계, 이미지 1/3 Sony Vaio VPCCW17FX Back Case: 5 단계, 이미지 2/3 Sony Vaio VPCCW17FX Back Case: 5 단계, 이미지 3/3
    • Remove the hard drive.
    • Using a Phillips #00 screwdriver, unscrew the two remaining 4.9 mm screws holding the hard drive into place.
    • Next, lift up and pull outwards to release the hard drive from its socket.
  6. Sony Vaio VPCCW17FX Back Case: 6 단계, 이미지 1/1
    • Using your fingers, grasp the black tab and lightly pull up on the ribbon cable to detach it from the motherboard.
  7. Sony Vaio VPCCW17FX Back Case: 7 단계, 이미지 1/1
    • After proper removal of all necessary screws, gently lift up on the back case to remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ellie DePorter
회원 가입일: 01/29/18
310 평판
안내서 2개 작성하였습니다
University of Alabama, Team S3-G9, Bedsole Spring 2018 University of Alabama, Team S3-G9, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S3G9
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 11
전체 시간: 958
