주요 콘텐츠로 건너뛰기
Sony Vaio VPCCW17FX Fan Replacement
필요한 것
  1. Sony Vaio VPCCW17FX Fan Replacement, Back case: 1 단계, 이미지 1/1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Fan Replacement: 2 단계, 이미지 1/3 Sony Vaio VPCCW17FX Fan Replacement: 2 단계, 이미지 2/3 Sony Vaio VPCCW17FX Fan Replacement: 2 단계, 이미지 3/3
    • Remove the battery by pinching the two lock tabs towards the center.
    • Next, lift up on the battery to remove it.
  3. Sony Vaio VPCCW17FX Fan Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the twenty-two 5.6 mm screws from the back of the laptop.
    • Be sure to remove all screws, including those that are typically covered by the battery.
  4. Sony Vaio VPCCW17FX Fan Replacement: 4 단계, 이미지 1/3 Sony Vaio VPCCW17FX Fan Replacement: 4 단계, 이미지 2/3 Sony Vaio VPCCW17FX Fan Replacement: 4 단계, 이미지 3/3
    • Now, remove the small covers from the back of the case.
    • Using a Phillips #00 screwdriver, unscrew the three 5.6 mm screws from the covers (one screw on the RAM cover [middle] and two screws on the Hard Drive cover [bottom right]).
    • Then, lift up on and remove these covers as shown in the third image.
  5. Sony Vaio VPCCW17FX Fan Replacement: 5 단계, 이미지 1/3 Sony Vaio VPCCW17FX Fan Replacement: 5 단계, 이미지 2/3 Sony Vaio VPCCW17FX Fan Replacement: 5 단계, 이미지 3/3
    • Remove the hard drive.
    • Using a Phillips #00 screwdriver, unscrew the two remaining 4.9 mm screws holding the hard drive into place.
    • Next, lift up and pull outwards to release the hard drive from its socket.
  6. Sony Vaio VPCCW17FX Fan Replacement: 6 단계, 이미지 1/1
    • Using your fingers, grasp the black tab and lightly pull up on the ribbon cable to detach it from the motherboard.
  7. Sony Vaio VPCCW17FX Fan Replacement: 7 단계, 이미지 1/1
    • After proper removal of all necessary screws, gently lift up on the back case to remove it.
  8. Sony Vaio VPCCW17FX Fan Replacement, Fan: 8 단계, 이미지 1/3 Sony Vaio VPCCW17FX Fan Replacement, Fan: 8 단계, 이미지 2/3 Sony Vaio VPCCW17FX Fan Replacement, Fan: 8 단계, 이미지 3/3
    • Locate the fan (top-right corner of the computer).
    • Using a Phillips #00 screwdriver, unscrew the six 2.7 mm screws that secure the fan to the motherboard.
  9. Sony Vaio VPCCW17FX Fan Replacement: 9 단계, 이미지 1/2 Sony Vaio VPCCW17FX Fan Replacement: 9 단계, 이미지 2/2
    • This step can be skipped if you are just removing the fan to access another part of the device (such as the motherboard).
    • Using a Japanese Industrial Standard #00 screwdriver, unscrew four 3.7 mm screws located on the casing of the fan.
  10. Sony Vaio VPCCW17FX Fan Replacement: 10 단계, 이미지 1/2 Sony Vaio VPCCW17FX Fan Replacement: 10 단계, 이미지 2/2
    • Using your fingers, grasp the white tab and firmly, yet gently, pull up on the wire to disconnect it from the motherboard.
결론
Ellie DePorter
회원 가입일: 01/29/18
310 평판
안내서 2개 작성하였습니다
University of Alabama, Team S3-G9, Bedsole Spring 2018 University of Alabama, Team S3-G9, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S3G9
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 1,008
