주요 콘텐츠로 건너뛰기
Sony Vaio VPCCW17FX Hard Drive Replacement
필요한 것
  1. Sony Vaio VPCCW17FX Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide the two latches towards the center of the battery to release it.
  3. Sony Vaio VPCCW17FX Hard Drive Replacement: 3 단계, 이미지 1/2 Sony Vaio VPCCW17FX Hard Drive Replacement: 3 단계, 이미지 2/2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Hard Drive Replacement: 4 단계, 이미지 1/2 Sony Vaio VPCCW17FX Hard Drive Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the two 7.7 mm screws from the hard drive cover and place it to the side.
  5. Sony Vaio VPCCW17FX Hard Drive Replacement: 5 단계, 이미지 1/3 Sony Vaio VPCCW17FX Hard Drive Replacement: 5 단계, 이미지 2/3 Sony Vaio VPCCW17FX Hard Drive Replacement: 5 단계, 이미지 3/3
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that hold the hard drive in place.
    • Use the tab to slide the hard drive away from the laptop.
    • Set the disconnected hard drive away from the laptop.
  6. Sony Vaio VPCCW17FX Hard Drive Replacement: 6 단계, 이미지 1/3 Sony Vaio VPCCW17FX Hard Drive Replacement: 6 단계, 이미지 2/3 Sony Vaio VPCCW17FX Hard Drive Replacement: 6 단계, 이미지 3/3
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that cover the hard drive.
    • Use the tab to pull up on the metal cover and remove it.
    • You are now free to replace the hard drive.
결론
Tiffani Beck
회원 가입일: 03/20/17
219 평판
안내서 2개 작성하였습니다
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 회원
TTU-BENNETT-S17S8G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 1,624
