주요 콘텐츠로 건너뛰기
Sony Vaio VPCCW17FX LCD Screen Replacement
필요한 것
  1. Sony Vaio VPCCW17FX LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX LCD Screen Replacement: 2 단계, 이미지 1/1
    • Slide both latches towards the center of the battery to release.
  3. Sony Vaio VPCCW17FX LCD Screen Replacement: 3 단계, 이미지 1/2 Sony Vaio VPCCW17FX LCD Screen Replacement: 3 단계, 이미지 2/2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX LCD Screen Replacement: 4 단계, 이미지 1/2 Sony Vaio VPCCW17FX LCD Screen Replacement: 4 단계, 이미지 2/2
    • Remove the rubber pads on all four corners of the screen bezel using the spudger.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver.
  5. Sony Vaio VPCCW17FX LCD Screen Replacement: 5 단계, 이미지 1/1
    • Remove the screen's plastic bezel.
    • You need to use slight pressure to release the clips.
  6. Sony Vaio VPCCW17FX LCD Screen Replacement: 6 단계, 이미지 1/2 Sony Vaio VPCCW17FX LCD Screen Replacement: 6 단계, 이미지 2/2
    • Remove all four screws (Length: 7.7 mm) using a Phillips #0 screwdriver. Make sure to hold the screen while removing the screws so it doesn't fall.
    • Using your thumb, carefully lower the glass and place it on the keyboard.
    • Do this slowly to avoid damaging the screen.
  7. Sony Vaio VPCCW17FX LCD Screen Replacement: 7 단계, 이미지 1/2 Sony Vaio VPCCW17FX LCD Screen Replacement: 7 단계, 이미지 2/2
    • Pull off the tape and disconnect the display cable connector by gently sliding up to remove it from its socket.
  8. Sony Vaio VPCCW17FX LCD Screen Replacement: 8 단계, 이미지 1/1
    • The screen can now be removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Seowon Song
회원 가입일: 03/20/17
113 평판
안내서 1개 작성함
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 회원
TTU-BENNETT-S17S8G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 8
전체 시간: 1,088
