소개
This guide will instruct users on how to properly and safely access and remove the motherboard in order to replace or repair it.
필요한 것
Now, remove the small covers from the back of the case.
Using a Phillips #00 screwdriver, unscrew the three 5.6 mm screws from the covers (one screw on the RAM cover [middle] and two screws on the Hard Drive cover [bottom right]).
Then, lift up on and remove these covers as shown in the third image.
Using your fingers, grasp the white and black wires connected to the wifi card. Pull up on these wires until they release from the card. Do not be afraid to use some force.
With your hand, grasp the side of the DVD/CD drive and gently pull it out of the socket, disconnecting it from the motherboard.
Using the Phillips #00 screwdriver, unscrew the two 4.9 mm screws depicted here.
Next, remove the metal cover to expose the bluetooth card.
Gently fit the flat end of a spudger under the edge of the bluetooth card. Then, lightly pry up on this edge to release the card from the motherboard. (Refer to the third image)
다른 한 분이 해당 안내서를 완성하였습니다.
