주요 콘텐츠로 건너뛰기
Sony Vaio VPCCW17FX RAM Replacement
필요한 것
  1. Sony Vaio VPCCW17FX RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX RAM Replacement: 2 단계, 이미지 1/1
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX RAM Replacement: 3 단계, 이미지 1/2 Sony Vaio VPCCW17FX RAM Replacement: 3 단계, 이미지 2/2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX RAM Replacement: 4 단계, 이미지 1/2 Sony Vaio VPCCW17FX RAM Replacement: 4 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) that is covering the RAM.
  5. Sony Vaio VPCCW17FX RAM Replacement: 5 단계, 이미지 1/1
    • Lift the black plastic cover to assess the RAM.
  6. Sony Vaio VPCCW17FX RAM Replacement: 6 단계, 이미지 1/3 Sony Vaio VPCCW17FX RAM Replacement: 6 단계, 이미지 2/3 Sony Vaio VPCCW17FX RAM Replacement: 6 단계, 이미지 3/3
    • Apply light, outward pressure to the locks on both sides of the RAM.
    • Rotate the RAM up and slowly pull towards you to remove it.
  7. Sony Vaio VPCCW17FX RAM Replacement: 7 단계, 이미지 1/3 Sony Vaio VPCCW17FX RAM Replacement: 7 단계, 이미지 2/3 Sony Vaio VPCCW17FX RAM Replacement: 7 단계, 이미지 3/3
    • In order to remove the secondary RAM, use the same outward pressure on the locks.
    • Lift and slide out the RAM to remove it from the slot.
결론
Mia Martinez
회원 가입일: 03/30/17
101 평판
안내서 1개 작성함
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 회원
TTU-BENNETT-S17S8G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 21
전체 시간: 1,124
