주요 콘텐츠로 건너뛰기
Sony Vaio VPCCW17FX Webcam Replacement
필요한 것
  1. Sony Vaio VPCCW17FX Webcam Replacement, Webcam: 1 단계, 이미지 1/1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Webcam Replacement: 2 단계, 이미지 1/1
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Webcam Replacement: 3 단계, 이미지 1/2 Sony Vaio VPCCW17FX Webcam Replacement: 3 단계, 이미지 2/2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Webcam Replacement: 4 단계, 이미지 1/2 Sony Vaio VPCCW17FX Webcam Replacement: 4 단계, 이미지 2/2
    • Remove the four rubber circles using the spudger located on each corner of the laptop.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver that are located under each rubber circle.
  5. Sony Vaio VPCCW17FX Webcam Replacement: 5 단계, 이미지 1/2 Sony Vaio VPCCW17FX Webcam Replacement: 5 단계, 이미지 2/2
    • Slowly peel off the plastic covering around the screen.
    • Place it to the side once it is completely disconnected.
    • You may need to apply slight pressure to release the clips of the covering.
  6. Sony Vaio VPCCW17FX Webcam Replacement: 6 단계, 이미지 1/3 Sony Vaio VPCCW17FX Webcam Replacement: 6 단계, 이미지 2/3 Sony Vaio VPCCW17FX Webcam Replacement: 6 단계, 이미지 3/3
    • Remove the two screws (Length: 7.7 mm) using the Phillips #0 screwdriver that hold the Webcam in place.
    • Gently pull the webcam away from the laptop.
    • Slowly disconnect the two ribbon cable connectors by sliding them towards the wire to disconnect the webcam from the laptop.
결론
Tiffani Beck
회원 가입일: 03/20/17
219 평판
안내서 2개 작성하였습니다
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 회원
TTU-BENNETT-S17S8G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 1,096
