주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
In this guide, you will learn to remove and replace the RAM of a Sony Vaio PCG-81312L computer.
부품
지정된 부품이 없습니다.
  1. Remove the single Phillips #00 screw from the back cover of the laptop.
    • Remove the single Phillips #00 screw from the back cover of the laptop.
  2. Lift the cover up and remove it from the computer.
    • Lift the cover up and remove it from the computer.
  3. Identify the two RAM pieces.
    • Identify the two RAM pieces.
  4. Push out the two outer white catch pieces holding the both sides of the RAM in position. Begin gently removing the RAM from its position. Push out the two outer white catch pieces holding the both sides of the RAM in position. Begin gently removing the RAM from its position.
    • Push out the two outer white catch pieces holding the both sides of the RAM in position. Begin gently removing the RAM from its position.
  5. Once you have the RAM out on its own, replace it or put it back into the correct position.
    • Once you have the RAM out on its own, replace it or put it back into the correct position.
결론
Matt Mersinger
회원 가입일: 2018년 10월 01일
419 평판
안내서 3개 작성하였습니다
McKendree University, Team S1-G3, Quinn Fall 2018 McKendree University, Team S1-G3, Quinn Fall 2018 회원
MCKU-QUINN-F18S1G3
2 회원들
안내서 3개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 426
