소개
During the life cycle of the Sony Vaio, you may encounter issues with certain key our your keyboard, hindering any work process you may be doing. This guide will help you fix this issue by removing the keyboard to make sure that everything is working fine
필요한 것
Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
Remove the 5mm screws with the PH0 screwdriver.
Remove the 3mm screws with the PH0 screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
