주요 콘텐츠로 건너뛰기
Sony Vaio PCG-61411L Optical Disc Drive Replacement
필요한 것
  1. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: 1 단계, 이미지 1/3 Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: 1 단계, 이미지 2/3 Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio PCG-61411L Optical Disc Drive Replacement: 2 단계, 이미지 1/3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 2 단계, 이미지 2/3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 2 단계, 이미지 3/3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Hard Drive: 3 단계, 이미지 1/1
    • The hard drive panel is located in the bottom right corner of the device.
  4. Sony Vaio PCG-61411L Optical Disc Drive Replacement: 4 단계, 이미지 1/2 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 4 단계, 이미지 2/2
    • Using the PH #0 screwdriver, unscrew the two 6.5mm screws located in the bottom left and middle right of the panel. The screws remain in the panels.
    • Remove the panel by pulling it up towards yourself.
  5. Sony Vaio PCG-61411L Optical Disc Drive Replacement: 5 단계, 이미지 1/3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 5 단계, 이미지 2/3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 5 단계, 이미지 3/3
    • Using a PH0 screwdriver, remove the four 3mm silver screws located in the external hard drive cover.
    • Using a PH00 screwdriver, remove the final 3mm black screw located in the top right section of the hard drive cover.
    • Carefully remove the silver hard drive cover.
  6. Sony Vaio PCG-61411L Optical Disc Drive Replacement: 6 단계, 이미지 1/3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 6 단계, 이미지 2/3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 6 단계, 이미지 3/3
    • Detach the hard drive by disconnecting it from the motherboard, pulling it gently from left to right.
  7. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Optical Disc Drive: 7 단계, 이미지 1/2 Sony Vaio PCG-61411L Optical Disc Drive Replacement, Optical Disc Drive: 7 단계, 이미지 2/2
    • Remove the 5mm screws with the PH0 screwdriver.
    • Remove the 3mm screws with the PH0 screwdriver.
  8. Sony Vaio PCG-61411L Optical Disc Drive Replacement: 8 단계, 이미지 1/2 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 8 단계, 이미지 2/2
    • Lift the backplate from bottom right and left corner and remove it from the laptop.
  9. Sony Vaio PCG-61411L Optical Disc Drive Replacement: 9 단계, 이미지 1/2 Sony Vaio PCG-61411L Optical Disc Drive Replacement: 9 단계, 이미지 2/2
    • Slide your finger from the right of the optical disc and pull the optical disc from right to left.
결론
Patrick Jean Baptiste
회원 가입일: 03/01/18
214 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S2-G1, Simcock Spring 2018 UMass Dartmouth, Team S2-G1, Simcock Spring 2018 회원
UMASSD-SIMCOCK-S18S2G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 18
전체 시간: 591
