주요 콘텐츠로 건너뛰기
Sony Vaio PCG-61411L RAM Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Sony Vaio PCG-61411L RAM Replacement, Battery: 1 단계, 이미지 1/3 Sony Vaio PCG-61411L RAM Replacement, Battery: 1 단계, 이미지 2/3 Sony Vaio PCG-61411L RAM Replacement, Battery: 1 단계, 이미지 3/3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio PCG-61411L RAM Replacement: 2 단계, 이미지 1/3 Sony Vaio PCG-61411L RAM Replacement: 2 단계, 이미지 2/3 Sony Vaio PCG-61411L RAM Replacement: 2 단계, 이미지 3/3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio PCG-61411L RAM Replacement, RAM: 3 단계, 이미지 1/1
    • The RAM cards reside in the rectangle shaped plate in the center of the back panel of the device.
  4. Sony Vaio PCG-61411L RAM Replacement: 4 단계, 이미지 1/2 Sony Vaio PCG-61411L RAM Replacement: 4 단계, 이미지 2/2
    • Unscrew the single PH1 6mm screw at the top of the panel. The screw remains in the panel.
    • Remove the panel by lifting it towards yourself.
  5. Sony Vaio PCG-61411L RAM Replacement: 5 단계, 이미지 1/3 Sony Vaio PCG-61411L RAM Replacement: 5 단계, 이미지 2/3 Sony Vaio PCG-61411L RAM Replacement: 5 단계, 이미지 3/3
    • To remove the individual RAM card panels, snap back the metal latches on each side of the cards.
  6. Sony Vaio PCG-61411L RAM Replacement: 6 단계, 이미지 1/2 Sony Vaio PCG-61411L RAM Replacement: 6 단계, 이미지 2/2
    • After pinching the metal latches, the RAM card should pop out slightly upward.
    • Remove the cards by pulling them out to the left.
    • Repeat for the second panel of RAM cards.
결론
Sean Lyon
회원 가입일: 03/01/18
381 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S2-G1, Simcock Spring 2018 UMass Dartmouth, Team S2-G1, Simcock Spring 2018 회원
UMASSD-SIMCOCK-S18S2G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 10
전체 시간: 1,156
