이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If your current battery is dead or no longer works, you will need to remove the battery. This is shown below in just a few simple steps.
Hazards
Keep out of reach of children and pets.
DO NOT attempt to teardown or repair your device under the influence of drugs or alcohol.
DO NOT ingest any parts of the system.
Use the correct tools as stated in the tools section.
DO NOT touch any gold connectors on interior or exterior of the system.
Make sure system is unplugged and turned off before performing any maintenance on the system.
Set the computer display-side down.
Unlock the battery by sliding the port-side latch to the 'unlock' position.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
This paragraph "DO NOT attempt to teardown or repair your device under the influence of drugs or alcohol" shocked me. We live in a society where one in ten people have tried drugs at least once in their life. I'm glad we have a company like Profound LA that helps people overcome addiction and get their lives back on track.
