주요 콘텐츠로 건너뛰기
Sony Vaio VPCEB11FM Cooling Fan Replacement
필요한 것
  1. Sony Vaio VPCEB11FM Cooling Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM Cooling Fan Replacement: 2 단계, 이미지 1/1
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM Cooling Fan Replacement: 3 단계, 이미지 1/1
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM Cooling Fan Replacement, RAM: 4 단계, 이미지 1/2 Sony Vaio VPCEB11FM Cooling Fan Replacement, RAM: 4 단계, 이미지 2/2
    • Unscrew the RAM cover plate using the Phillips #1 Screwdriver.
    • Once the cover has been loosened, pry the cover with your finger for it to come off.
  5. Sony Vaio VPCEB11FM Cooling Fan Replacement: 5 단계, 이미지 1/3 Sony Vaio VPCEB11FM Cooling Fan Replacement: 5 단계, 이미지 2/3 Sony Vaio VPCEB11FM Cooling Fan Replacement: 5 단계, 이미지 3/3
    • Use your fingers to gently pull the white plastic strip outward on both sides.
    • Once you pull the strip, the strip of RAM will loosen up. Once loose the strip of RAM should lift out.
    • Once done with the top strip of RAM continue for all continuous strips.
  6. Sony Vaio VPCEB11FM Cooling Fan Replacement, Hard Drive: 6 단계, 이미지 1/2 Sony Vaio VPCEB11FM Cooling Fan Replacement, Hard Drive: 6 단계, 이미지 2/2
    • Using the Phillips #01 Screwdriver, remove the two 7mm screws.
  7. Sony Vaio VPCEB11FM Cooling Fan Replacement: 7 단계, 이미지 1/3 Sony Vaio VPCEB11FM Cooling Fan Replacement: 7 단계, 이미지 2/3 Sony Vaio VPCEB11FM Cooling Fan Replacement: 7 단계, 이미지 3/3
    • Use your fingers to pry the cover upward.
    • Unscrew the two 7mm screws.
    • Pull the plastic tab in the direction of the arrow to take out.
  8. Sony Vaio VPCEB11FM Cooling Fan Replacement: 8 단계, 이미지 1/2 Sony Vaio VPCEB11FM Cooling Fan Replacement: 8 단계, 이미지 2/2
    • Lift plug side first.
    • Remove all the way.
  9. Sony Vaio VPCEB11FM Cooling Fan Replacement: 9 단계, 이미지 1/3 Sony Vaio VPCEB11FM Cooling Fan Replacement: 9 단계, 이미지 2/3 Sony Vaio VPCEB11FM Cooling Fan Replacement: 9 단계, 이미지 3/3
    • Skip to next step if accessing other components.
    • Remove the 3mm screws with the Phillips #1 Screwdriver from hard drive bracket.
  10. Sony Vaio VPCEB11FM Cooling Fan Replacement, DVD Drive: 10 단계, 이미지 1/2 Sony Vaio VPCEB11FM Cooling Fan Replacement, DVD Drive: 10 단계, 이미지 2/2
    • Remove the 7mm screws with the Phillips #1 Screwdriver.
  11. Sony Vaio VPCEB11FM Cooling Fan Replacement: 11 단계, 이미지 1/1
    • Grasp the DVD drive's face plate with your fingers and pull out.
  12. Sony Vaio VPCEB11FM Cooling Fan Replacement, Cooling Fan: 12 단계, 이미지 1/3 Sony Vaio VPCEB11FM Cooling Fan Replacement, Cooling Fan: 12 단계, 이미지 2/3 Sony Vaio VPCEB11FM Cooling Fan Replacement, Cooling Fan: 12 단계, 이미지 3/3
    • Remove ten 7mm screws with the Phillips #1 Screwdriver.
    • Remove two 8mm screws with the Phillips #1 Screwdriver.
    • Remove two 3mm screws with the Phillips #1 Screwdriver.
  13. Sony Vaio VPCEB11FM Cooling Fan Replacement: 13 단계, 이미지 1/2 Sony Vaio VPCEB11FM Cooling Fan Replacement: 13 단계, 이미지 2/2
    • Remove SD card slot block by pushing it in until it releases.
    • Once released pull out to remove.
  14. Sony Vaio VPCEB11FM Cooling Fan Replacement: 14 단계, 이미지 1/3 Sony Vaio VPCEB11FM Cooling Fan Replacement: 14 단계, 이미지 2/3 Sony Vaio VPCEB11FM Cooling Fan Replacement: 14 단계, 이미지 3/3
    • To take off the cover plate, start by finding a loose corner to begin prying it open.
    • Work the tool around the sides to release the cover. You may need a second tool to help keep your loose corner open.
    • Lift cover away.
    • NOTE: If you are attempting to access other components, skip 2 steps.
  15. Sony Vaio VPCEB11FM Cooling Fan Replacement: 15 단계, 이미지 1/3 Sony Vaio VPCEB11FM Cooling Fan Replacement: 15 단계, 이미지 2/3 Sony Vaio VPCEB11FM Cooling Fan Replacement: 15 단계, 이미지 3/3
    • Remove the plug shown using a pry tool.
    • Remove seven 5mm screws with the Phillips #01 Screwdriver.
  16. Sony Vaio VPCEB11FM Cooling Fan Replacement: 16 단계, 이미지 1/3 Sony Vaio VPCEB11FM Cooling Fan Replacement: 16 단계, 이미지 2/3 Sony Vaio VPCEB11FM Cooling Fan Replacement: 16 단계, 이미지 3/3
    • To break the thermal paste, apply gentle constant upward force until it comes free.
    • Remove four 3.5mm screws with the Phillips #000 Screwdriver to access cooling fan.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Maxine Filcher
회원 가입일: 01/30/17
1,135 평판
안내서 8개 작성하였습니다
UW Tacoma, Team 1-5, Rose Winter 2017 UW Tacoma, Team 1-5, Rose Winter 2017 회원
UWT-ROSE-W17S1G5
4 회원들
안내서 16개 작성하였습니다
댓글 한 개
Wonderful guide, helped me upgrade the CPU on my laptop and clean the insides out while I was at it.
William - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 1,930
