주요 콘텐츠로 건너뛰기
Sony Vaio VPCEB11FM Keyboard Replacement
필요한 것
  1. Sony Vaio VPCEB11FM Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM Keyboard Replacement: 2 단계, 이미지 1/1
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM Keyboard Replacement: 3 단계, 이미지 1/1
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM Keyboard Replacement, DVD Drive: 4 단계, 이미지 1/2 Sony Vaio VPCEB11FM Keyboard Replacement, DVD Drive: 4 단계, 이미지 2/2
    • Remove the 7mm screws with the Phillips #1 Screwdriver.
  5. Sony Vaio VPCEB11FM Keyboard Replacement: 5 단계, 이미지 1/1
    • Grasp the DVD drive's face plate with your fingers and pull out.
  6. Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: 6 단계, 이미지 1/3 Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: 6 단계, 이미지 2/3 Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: 6 단계, 이미지 3/3
    • Within the DVD drive compartment, press on the hole to push the keyboard out of its placement.
    • The keyboard may need to be loosened on its edges with a plastic spudger.
  7. Sony Vaio VPCEB11FM Keyboard Replacement: 7 단계, 이미지 1/3 Sony Vaio VPCEB11FM Keyboard Replacement: 7 단계, 이미지 2/3 Sony Vaio VPCEB11FM Keyboard Replacement: 7 단계, 이미지 3/3
    • Carefully pull the keyboard back to expose ribbon connector.
    • Using a spudger, or your finger tips, carefully slide the the ribbon keeper open.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Maxine Filcher
회원 가입일: 01/30/17
1,135 평판
안내서 8개 작성하였습니다
UW Tacoma, Team 1-5, Rose Winter 2017 UW Tacoma, Team 1-5, Rose Winter 2017 회원
UWT-ROSE-W17S1G5
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 1,935
