주요 콘텐츠로 건너뛰기
Sony Vaio VPCEB11FM RAM Replacement
필요한 것
  1. Sony Vaio VPCEB11FM RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM RAM Replacement: 2 단계, 이미지 1/1
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM RAM Replacement: 3 단계, 이미지 1/1
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM RAM Replacement, RAM: 4 단계, 이미지 1/2 Sony Vaio VPCEB11FM RAM Replacement, RAM: 4 단계, 이미지 2/2
    • Unscrew the RAM cover plate using the Phillips #1 Screwdriver.
    • Once the cover has been loosened, pry the cover with your finger for it to come off.
  5. Sony Vaio VPCEB11FM RAM Replacement: 5 단계, 이미지 1/3 Sony Vaio VPCEB11FM RAM Replacement: 5 단계, 이미지 2/3 Sony Vaio VPCEB11FM RAM Replacement: 5 단계, 이미지 3/3
    • Use your fingers to gently pull the white plastic strip outward on both sides.
    • Once you pull the strip, the strip of RAM will loosen up. Once loose the strip of RAM should lift out.
    • Once done with the top strip of RAM continue for all continuous strips.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Maxine Filcher
회원 가입일: 01/30/17
1,135 평판
안내서 8개 작성하였습니다
UW Tacoma, Team 1-5, Rose Winter 2017 UW Tacoma, Team 1-5, Rose Winter 2017 회원
UWT-ROSE-W17S1G5
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 1,611
