소개
Watch out for applying to much pressure to your screen because it is possible to damage the screen by applying pressure or by bending the screen.
필요한 것
Now that the backing plate is off make sure to be careful of the Motherboard and its components from being damaged. from here on out it is recommended that you wear a anti static bracelet or at the very least touching something metal to remove any static electricity that you may have built up
다른 한 분이 해당 안내서를 완성하였습니다.
