주요 콘텐츠로 건너뛰기
Sony Vaio VPCCB290X LCD Screen Replacement
필요한 것
  1. Sony Vaio VPCCB290X LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/1
    • First make sure the laptop is off and closed.
  2. Sony Vaio VPCCB290X LCD Screen Replacement: 2 단계, 이미지 1/1
    • Unlock the battery and push the release lever to remove the battery from the laptop.
  3. Sony Vaio VPCCB290X LCD Screen Replacement: 3 단계, 이미지 1/2 Sony Vaio VPCCB290X LCD Screen Replacement: 3 단계, 이미지 2/2
    • Remove the screws marked in red to remove the hard drive cover and the screws marked in blue to loosen the hard drive. Then gently slide the hard drive out.
  4. Sony Vaio VPCCB290X LCD Screen Replacement: 4 단계, 이미지 1/1
    • Remove all the screws that hold the plastic bottom on. There are some more screws that cant be seen in the photo.
  5. Sony Vaio VPCCB290X LCD Screen Replacement: 5 단계, 이미지 1/1
    • Gently pry up the plastic bottom and if it feels like it is resisting check the surrounding areas for more screws.
  6. Sony Vaio VPCCB290X LCD Screen Replacement: 6 단계, 이미지 1/1
    • Now that the backing plate is off make sure to be careful of the Motherboard and its components from being damaged. from here on out it is recommended that you wear a anti static bracelet or at the very least touching something metal to remove any static electricity that you may have built up
  7. Sony Vaio VPCCB290X LCD Screen Replacement: 7 단계, 이미지 1/1
    • Use a common or lat head screw driver to gently untangle the wires from their paths.
  8. Sony Vaio VPCCB290X LCD Screen Replacement: 8 단계, 이미지 1/2 Sony Vaio VPCCB290X LCD Screen Replacement: 8 단계, 이미지 2/2
    • You will need to unscrew this small circuit board and fold it up to get the wires out from under it.
  9. Sony Vaio VPCCB290X LCD Screen Replacement: 9 단계, 이미지 1/1
    • Disconnect the screen from the motherboard.
  10. Sony Vaio VPCCB290X LCD Screen Replacement: 10 단계, 이미지 1/1
    • They are two hinges that hold the screen on. Make sure to pay attention to where the screws come from in order to put them back and to make installation easier.
  11. Sony Vaio VPCCB290X LCD Screen Replacement: 11 단계, 이미지 1/1
    • By folding up the hinges the screen will simply slide away from the body of the computer and you can then put the new screen into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Eric Martinez
회원 가입일: 02/14/17
637 평판
안내서 6개 작성하였습니다
USF Tampa, Team 20-5, Remmell Spring 2017 USF Tampa, Team 20-5, Remmell Spring 2017 회원
USFT-REMMELL-S17S20G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 755
