주요 콘텐츠로 건너뛰기
Sony Vaio VGN-NW240F (PCG-7184L) Optical Drive Replacement
필요한 것
  1. Sony Vaio VGN-NW240F (PCG-7184L) Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
    • There will be three dots next to the desired screws
  2. Sony Vaio VGN-NW240F (PCG-7184L) Optical Drive Replacement: 2 단계, 이미지 1/1
    • Grip the cover of the optical drive and slide it out.
    • If it does not come out, do not force it. Double check to make sure the screws are entirely removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kevin McGowan
회원 가입일: 04/22/14
619 평판
안내서 4개 작성하였습니다
Cal Poly, Team 9-17, Regan Spring 2014 Cal Poly, Team 9-17, Regan Spring 2014 회원
CPSU-REGAN-S14S9G17
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
Has anyone found a suitable optical enclosure that would accommodate the front edge of this drive? Every enclosure I've seen so far would have the door protruding past the enclosure's opening (as opposed to sitting flush with the enclosure's opening), leaving its top edge unprotected.
Lotus Flower - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 1,748
