주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide will show and demonstrate how to remove and replace the battery in a Sony Vaio PCG-71C11L laptop.
도구
부품
지정된 부품이 없습니다.
  1. Slide the switch with the word "lock" above it to the unlocked position. Slide the switch with the word "lock" above it to the unlocked position.
    • Slide the switch with the word "lock" above it to the unlocked position.
  2. Hold the switch that says "Release" to the open position while pulling up on the side of the battery with the groove. Once the battery is flipped up, it can easily be removed. Hold the switch that says "Release" to the open position while pulling up on the side of the battery with the groove. Once the battery is flipped up, it can easily be removed.
    • Hold the switch that says "Release" to the open position while pulling up on the side of the battery with the groove. Once the battery is flipped up, it can easily be removed.
결론
charles cochran
회원 가입일: 2018년 09월 21일
101 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 221
