주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Replacing the disc drive is a relatively easy procedure, requiring only one screw to remove. The hardest part will be tracking down a replacement, which will likely be found in the secondhand market, like eBay.
부품
지정된 부품이 없습니다.
  1. Unscrew the screw in the hole marked by three vertical dots, shown here.
    • Unscrew the screw in the hole marked by three vertical dots, shown here.
    • The screw is located on the bottom panel of the computer, next to the information panel with the production date.
  2. Pull out the 0.6 mm screw, or rotate the laptop and let it fall out.
    • Pull out the 0.6 mm screw, or rotate the laptop and let it fall out.
    • Be sure to not lose track of this screw, it holds the disc drive in place.
  3. Gently pull the edge of the disc drive until you feel it start to come out. Pull it all the way out, and set it aside.
    • Gently pull the edge of the disc drive until you feel it start to come out. Pull it all the way out, and set it aside.
결론
Nick Sanchez
회원 가입일: 2018년 09월 21일
97 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 207
