주요 콘텐츠로 건너뛰기
Sony Vaio VPCEL17FX Hard Drive Replacement
필요한 것
  1. Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/3 Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/3 Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3/3
    • First, locate the hard drive slot on the under side of the laptop.
    • Unscrew the screws using your Phillips #00 screwdriver.
    • Set the two screws aside so you can screw them in later on when you're finished.
    • This should reveal a small metallic place holder that your hard drive belongs.
  2. Sony Vaio VPCEL17FX Hard Drive Replacement: 2 단계, 이미지 1/2 Sony Vaio VPCEL17FX Hard Drive Replacement: 2 단계, 이미지 2/2
    • Unscrew the 4 hard drive bracket screws.
    • Once the screw is undone you can pull the place holder back to find the slot where the actual hard drive belongs.
    • Remember to set aside the screw so you can correctly install the hard drive.
결론
The installation/replacement is a very easy task that can be done by anyone.
Alberto Rosas
회원 가입일: 09/21/18
152 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 608
