이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide helps users replace the RAM in the Sony Vaio PCG-7A2L laptop.
필요한 것
With the bottom of the laptop facing up, locate the RAM cover.
The RAM is covered by the panel with four columns of vents.
Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
To remove the RAM, use sharp end of a spudger to push the two silver tabs (see picture) away from the green RAM chip.
When both silver tabs are moved to the side, one edge of the RAM chip will pop up from its original position.
Use your fingers to grab the raised edge of the RAM and pull the chip away from its connection to the laptop.
To finish the RAM installation, use your finger to push down on the center of the RAM until it clips into the silver tabs and locks into place.
Work backwards through the Disassembling Ram Cover Guide and then the Disassembling Battery Guide to reassemble your laptop.
다른 2명이 해당 안내서를 완성하였습니다.
