소개
The disk drive replacement is intended to show a simple way to remove and replace a disk drive.
Note: Do not pull disk drive out with force, as it can damage disk drive panel.
필요한 것
Remove the 9mm Phillips #1 screw holding the disk drive in place.
Remove the 9mm screw near the memory stick.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
