주요 콘텐츠로 건너뛰기
Sony Vaio PCG-981L Battery Replacement
  1. Sony Vaio PCG-981L Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Before starting, be sure the device is turned off and disconnected from any power cords.
    • Place the device on a flat surface.
  2. Sony Vaio PCG-981L Battery Replacement: 2 단계, 이미지 1/1
    • Rotate the device 90° counterclockwise until the battery cover is in front of you.
    • The battery cover is located in the lower right side of the device in this new orientation.
  3. Sony Vaio PCG-981L Battery Replacement: 3 단계, 이미지 1/1
    • Flip the laptop over so that the bottom is facing up but the battery cover is still facing you.
    • In this new orientation, the battery cover is located on the left side.
  4. Sony Vaio PCG-981L Battery Replacement: 4 단계, 이미지 1/1
    • To remove the battery cover, use your hands to slide it upwards.
  5. Sony Vaio PCG-981L Battery Replacement: 5 단계, 이미지 1/3 Sony Vaio PCG-981L Battery Replacement: 5 단계, 이미지 2/3 Sony Vaio PCG-981L Battery Replacement: 5 단계, 이미지 3/3
    • Once lifted, the battery cover should flip open.
    • Now, carefully remove the battery from the device.
  6. Sony Vaio PCG-981L Battery Replacement: 6 단계, 이미지 1/2 Sony Vaio PCG-981L Battery Replacement: 6 단계, 이미지 2/2
    • Now, the battery should be completely removed from the device.
    • Be sure to dispose of the old battery properly and then you are finished.
결론
Enjoy your new battery.
Gabriel Camorlinga
회원 가입일: 04/20/10
43 평판
안내서 2개 작성하였습니다
Cal Poly, Team 18-68, Johann Spring 2010 Cal Poly, Team 18-68, Johann Spring 2010 회원
CPSU-JOHANN-S10S18G68
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 3,832
