소개
The purpose of this guidelines is to show user how to remove the DVD drive and reinstall a new one. Please follow instructions carefully for successful results.
  1. These are the parts of the laptop that you will need to know about: Power panel: shown in photo 1. Power panel ribbon: located on the back of the power panel. This is the white ribbon in photo 2.
    • These are the parts of the laptop that you will need to know about:
    • Power panel: shown in photo 1.
    • Power panel ribbon: located on the back of the power panel. This is the white ribbon in photo 2.
    • Keyboard and keyboard ribbon. Ribbon is located within the red box highlighter in photo 3.
  2. Keep laptop sitting on table to avoid dropping it and causing irreparable damage. Open Laptop. Using a Phillips screwdriver, remove power panel screw located on the left side of the laptop. See red box in photo for screw location.
    • Keep laptop sitting on table to avoid dropping it and causing irreparable damage.
    • Open Laptop.
    • Using a Phillips screwdriver, remove power panel screw located on the left side of the laptop. See red box in photo for screw location.
    • To remove power panel, slide it to the right and gently lift upwards.
    • Gently detach power panel ribbon from the motherboard by sliding the ribbon out of plastic connector keeping it attached to power panel.
  3. Detach keyboard ribbon cable from motherboard. Lift top latch of plastic connection piece and ribbon cable will be able to slide out. Slide keyboard out. Photo 3 shows the DVD drive once the power panel and keyboard tray have been removed.
    • Detach keyboard ribbon cable from motherboard.
    • Lift top latch of plastic connection piece and ribbon cable will be able to slide out. Slide keyboard out.
    • Photo 3 shows the DVD drive once the power panel and keyboard tray have been removed.
  4. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  5. Remove first screw from the DVD drive with Philips screwdriver. Refer to photo 1 for screw's location. Remove second screw from the DVD drive with Philips screwdriver. Refer to photo for screw's location. Remove second screw from the DVD drive with Philips screwdriver. Refer to photo for screw's location.
    • Remove first screw from the DVD drive with Philips screwdriver. Refer to photo 1 for screw's location.
    • Remove second screw from the DVD drive with Philips screwdriver. Refer to photo for screw's location.
  6. Gently detach ribbon cable from the DVD drive. Pull the hard part of the cable straight back from the DVD drive. Remove DVD drive from laptop by gently sliding it out through the outside of the laptop. Remove DVD drive from laptop by gently sliding it out through the outside of the laptop.
    • Gently detach ribbon cable from the DVD drive. Pull the hard part of the cable straight back from the DVD drive.
    • Remove DVD drive from laptop by gently sliding it out through the outside of the laptop.
  7. Congratulations! You have just successfully removed the DVD drive. You are now ready to install new DVD drive. Congratulations! You have just successfully removed the DVD drive. You are now ready to install new DVD drive.
    • Congratulations! You have just successfully removed the DVD drive. You are now ready to install new DVD drive.
  8. Gently slide DVD drive into laptop. If the drive gets stuck while sliding in, gently push down on metal bay below DVD drive to allow DVD drive to slide over. Reattach ribbon cable to DVD drive. Replace both DVD drive screws. See photo for reference.
    • Gently slide DVD drive into laptop. If the drive gets stuck while sliding in, gently push down on metal bay below DVD drive to allow DVD drive to slide over.
    • Reattach ribbon cable to DVD drive.
    • Replace both DVD drive screws. See photo for reference.
  9. Reattach keyboard ribbon cable to motherboard. Slide ribbon cable into plastic connector and then push top down to latch. Slide keyboard back into place. Reattach power panel ribbon cable to motherboard. Slide power panel into place. Reattach power panel ribbon cable to motherboard. Slide power panel into place.
    • Reattach keyboard ribbon cable to motherboard. Slide ribbon cable into plastic connector and then push top down to latch. Slide keyboard back into place.
    • Reattach power panel ribbon cable to motherboard. Slide power panel into place.
  10. Replace power panel side screw. Congratulations! The installation is now complete!
    • Replace power panel side screw.
    • Congratulations! The installation is now complete!
결승점
Genaro Sanchez
회원 가입일: 2010년 04월 14일
46 평판
안내서 2개 작성하였습니다
Cal Poly, Team 18-68, Johann Spring 2010 Cal Poly, Team 18-68, Johann Spring 2010 회원
CPSU-JOHANN-S10S18G68
4 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 3
전체 시간: 4,800
