이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The purpose of this guidelines is to show user how to remove the DVD drive and reinstall a new one. Please follow instructions carefully for successful results.
필요한 것
These are the parts of the laptop that you will need to know about:
Power panel: shown in photo 1.
Power panel ribbon: located on the back of the power panel. This is the white ribbon in photo 2.
Keyboard and keyboard ribbon. Ribbon is located within the red box highlighter in photo 3.
Open Laptop.
Using a Phillips screwdriver, remove power panel screw located on the left side of the laptop. See red box in photo for screw location.
To remove power panel, slide it to the right and gently lift upwards.
Gently detach power panel ribbon from the motherboard by sliding the ribbon out of plastic connector keeping it attached to power panel.
