주요 콘텐츠로 건너뛰기
Sony Vaio PCG-981L Floppy Drive Replacement
필요한 것
  1. Sony Vaio PCG-981L Floppy Drive Replacement, Floppy Drive: 1 단계, 이미지 1/1
    • Turn the device over so that its underside is facing up. Then, slide the blue floppy drive release button down and pull the floppy drive out of the laptop.
  2. Sony Vaio PCG-981L Floppy Drive Replacement: 2 단계, 이미지 1/1
    • Remove the floppy drive from the laptop.
  3. Sony Vaio PCG-981L Floppy Drive Replacement: 3 단계, 이미지 1/1
    • There are two screws on each side of the floppy drive (four screws total). Remove these screws.
  4. Sony Vaio PCG-981L Floppy Drive Replacement: 4 단계, 이미지 1/1
    • Remove the floppy drive core from its casing.
  5. Sony Vaio PCG-981L Floppy Drive Replacement: 5 단계, 이미지 1/1
    • Unscrew the five screws from the back of the optical drive.
  6. Sony Vaio PCG-981L Floppy Drive Replacement: 6 단계, 이미지 1/1
    • Remove the two screws holding part of the floppy processing unit.
  7. Sony Vaio PCG-981L Floppy Drive Replacement: 7 단계, 이미지 1/1
    • Remove the entire floppy drive processing unit.
  8. Sony Vaio PCG-981L Floppy Drive Replacement: 8 단계, 이미지 1/1
    • Here is an isolated image of the core hardware of the floppy drive. This is where the floppy "magic" happens. Check for any connection failures or shortages. You may need to resolder some of the connections.
  9. Sony Vaio PCG-981L Floppy Drive Replacement: 9 단계, 이미지 1/1
    • Here is an isolated image of the floppy drive casing unit.
결론
Loratious
회원 가입일: 04/20/10
10 평판
안내서 1개 작성함
Cal Poly, Team 18-68, Johann Spring 2010 Cal Poly, Team 18-68, Johann Spring 2010 회원
CPSU-JOHANN-S10S18G68
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 2,725
