주요 콘텐츠로 건너뛰기
Sony Vaio PCG-F360 Keyboard Replacement
필요한 것
  1. Sony Vaio PCG-F360 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony Vaio PCG-F360 Keyboard Replacement: 2 단계, 이미지 1/1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony Vaio PCG-F360 Keyboard Replacement: 3 단계, 이미지 1/1
    • Use the indentations to pull the old battery out.
  4. Sony Vaio PCG-F360 Keyboard Replacement: 4 단계, 이미지 1/1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony Vaio PCG-F360 Keyboard Replacement, Keyboard: 5 단계, 이미지 1/3 Sony Vaio PCG-F360 Keyboard Replacement, Keyboard: 5 단계, 이미지 2/3 Sony Vaio PCG-F360 Keyboard Replacement, Keyboard: 5 단계, 이미지 3/3
    • There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony Vaio PCG-F360 Keyboard Replacement: 6 단계, 이미지 1/3 Sony Vaio PCG-F360 Keyboard Replacement: 6 단계, 이미지 2/3 Sony Vaio PCG-F360 Keyboard Replacement: 6 단계, 이미지 3/3
    • On the inside of the speaker panel, using a spudger, push the beige tab in the direction of the ribbon. It should only move a small amount.
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
  7. Sony Vaio PCG-F360 Keyboard Replacement: 7 단계, 이미지 1/2 Sony Vaio PCG-F360 Keyboard Replacement: 7 단계, 이미지 2/2
    • Remove the metal screw that will be located at the red circle.
    • Pull on the green strip, and the keyboard should come free easily.
결론
ahintz
회원 가입일: 04/21/10
28 평판
안내서 8개 작성하였습니다
Cal Poly, Team 16-3, Maness Spring 2010 Cal Poly, Team 16-3, Maness Spring 2010 회원
CPSU-MANESS-S10S16G3
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 1,371
