주요 콘텐츠로 건너뛰기
Sony Vaio PCG-F420 Battery Replacement
  1. Sony Vaio PCG-F420 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • The battery is located on the left side of the laptop, as shown by the red circle.
    • Make sure the laptop is disconnected and turned completely off.
  2. Sony Vaio PCG-F420 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the battery by following these steps.
    • Pull the plastic cover down (indicated by the arrow on the cover) and then swing it upwards to reveal the battery compartment.
    • The battery can now be removed by pulling it.
결론
Mohan Singhal
회원 가입일: 04/19/10
22 평판
안내서 1개 작성함
Cal Poly, Team 29-77, Johann Spring 2010 Cal Poly, Team 29-77, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G77
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,561
