주요 콘텐츠로 건너뛰기
Sony Vaio PCG-F420 CD/DVD Drive Replacement
필요한 것
  1. Sony Vaio PCG-F420 CD/DVD Drive Replacement, Battery: 1 단계, 이미지 1/1
    • The battery is located on the left side of the laptop, as shown by the red circle.
    • Make sure the laptop is disconnected and turned completely off.
  2. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 2 단계, 이미지 1/1
    • Remove the battery by following these steps.
    • Pull the plastic cover down (indicated by the arrow on the cover) and then swing it upwards to reveal the battery compartment.
    • The battery can now be removed by pulling it.
  3. Sony Vaio PCG-F420 CD/DVD Drive Replacement, Keyboard: 3 단계, 이미지 1/1
    • Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
  4. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 4 단계, 이미지 1/1
    • Unlock the cover between the keyboard and screen.
    • Gently slide it to the right and lift it up.
    • Exercise caution to avoid excessive force, as wires are connected.
    • Be mindful not to pull the keyboard too forcefully as it remains connected to wires, which we will address in the next step.
  5. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 5 단계, 이미지 1/1
    • Lift up the cover and lean it against the display so it is out of the way for the rest of the process.
    • Remove the small screw above the F6 key on the keyboard. Place screw in container to ensure it wont be lost.
  6. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 6 단계, 이미지 1/1
    • Find the green ribbon as indicated in the picture by the red circle. This is what connects the keyboard to the motherboard.
  7. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 7 단계, 이미지 1/1
    • Carefully unplug the ribbon cable using a pair of tweezers.
    • Lift up the white bar near the connection to the motherboard, and lightly lift the ribbon to release it from the motherboard.
  8. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 8 단계, 이미지 1/2 Sony Vaio PCG-F420 CD/DVD Drive Replacement: 8 단계, 이미지 2/2
    • Now, pull on the ribbon cable, and it will detach from the motherboard.
    • Your keyboard is now safely detached, allowing for necessary repairs or replacements.
  9. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 9 단계, 이미지 1/1
    • Your keyboard is now safety detached. Necessary repairs or replacements can be made from here.
  10. Sony Vaio PCG-F420 CD/DVD Drive Replacement, CD/DVD Drive: 10 단계, 이미지 1/1
    • After removing the keyboard, unscrew (using Phillips #00) the circled screw securing the CD/DVD drive.
  11. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 11 단계, 이미지 1/1
    • After unscrewing the CD/DVD drive, gently slide the drive slightly out of the main computer case, as shown. Be careful not to rip off the harness.
  12. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 12 단계, 이미지 1/1
    • Carefully detach the harness from the CD/DVD drive. Use your fingers if possible, but if not carefully use a pair of tweezers to detach the harness. Take care in not bending any of the pin connections.
  13. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 13 단계, 이미지 1/1
    • After disconnecting the harness you can now slide the CD/DVD drive fully out of the computer. You can now repair or replace your CD/DVD drive.
결론
Andrew Quayle
회원 가입일: 04/15/10
44 평판
안내서 2개 작성하였습니다
Cal Poly, Team 29-77, Johann Spring 2010 Cal Poly, Team 29-77, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G77
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 15
전체 시간: 4,037
