주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Vaio PCG-F420 Hard Drive Replacement
필요한 것
  1. Sony Vaio PCG-F420 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • The battery is located on the left side of the laptop, as shown by the red circle.
    • Make sure the laptop is disconnected and turned completely off.
  2. Sony Vaio PCG-F420 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery by following these steps.
    • Pull the plastic cover down (indicated by the arrow on the cover) and then swing it upwards to reveal the battery compartment.
    • The battery can now be removed by pulling it.
  3. Sony Vaio PCG-F420 Hard Drive Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
  4. Sony Vaio PCG-F420 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Unlock the cover between the keyboard and screen.
    • Gently slide it to the right and lift it up.
    • Exercise caution to avoid excessive force, as wires are connected.
    • Be mindful not to pull the keyboard too forcefully as it remains connected to wires, which we will address in the next step.
  5. Sony Vaio PCG-F420 Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Lift up the cover and lean it against the display so it is out of the way for the rest of the process.
    • Remove the small screw above the F6 key on the keyboard. Place screw in container to ensure it wont be lost.
  6. Sony Vaio PCG-F420 Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Find the green ribbon as indicated in the picture by the red circle. This is what connects the keyboard to the motherboard.
  7. Sony Vaio PCG-F420 Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Carefully unplug the ribbon cable using a pair of tweezers.
    • Lift up the white bar near the connection to the motherboard, and lightly lift the ribbon to release it from the motherboard.
  8. Sony Vaio PCG-F420 Hard Drive Replacement: 8 단계, 이미지 2개 중 1개 Sony Vaio PCG-F420 Hard Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Now, pull on the ribbon cable, and it will detach from the motherboard.
    • Your keyboard is now safely detached, allowing for necessary repairs or replacements.
  9. Sony Vaio PCG-F420 Hard Drive Replacement: 9 단계, 이미지 1개 중 1개
    • Your keyboard is now safety detached. Necessary repairs or replacements can be made from here.
  10. Sony Vaio PCG-F420 Hard Drive Replacement, Hard Drive: 10 단계, 이미지 1개 중 1개
    • The hard drive is the metal box in the middle. Use your Philips Head screwdriver to remove the four screws that attach the cage to the motherboard.
  11. Sony Vaio PCG-F420 Hard Drive Replacement: 11 단계, 이미지 1개 중 1개
    • The Hard Drive box is now unfastened. You can free it from the laptop by pulling up, but be careful because it is held in place by the surrounding metal pieces so a little strength, yet care, is needed. When free, do not immediately remove it, there is a ribbon cable connecting it to the laptop.
  12. Sony Vaio PCG-F420 Hard Drive Replacement: 12 단계, 이미지 1개 중 1개
    • Slowly pull the hard drive away from the ribbon by holding the plastic connector at the end of the ribbon and pulling on the Hard Drive. The Hard Drive should now be completely free of the laptop and the two connecting ends displayed in the picture should be visible.
  13. Sony Vaio PCG-F420 Hard Drive Replacement: 13 단계, 이미지 1개 중 1개
    • The hard drive is attached to the metal outer case by four screws, two on each side.
  14. Sony Vaio PCG-F420 Hard Drive Replacement: 14 단계, 이미지 1개 중 1개
    • The Hard Drive is now exposed. You are now free to replace it, clean it, or repair it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
john franzino
회원 가입일: 04/28/10
1 평판
안내서 1개를 작성함
Cal Poly, Team 29-77, Johann Spring 2010 Cal Poly, Team 29-77, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G77
5 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 62
전체 시간: 8,569
