주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Sony Vaio PCG-F420 Keyboard Replacement
필요한 것
  1. Sony Vaio PCG-F420 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • The battery is located on the left side of the laptop, as shown by the red circle.
    • Make sure the laptop is disconnected and turned completely off.
  2. Sony Vaio PCG-F420 Keyboard Replacement: 2 단계, 이미지 1/1
    • Remove the battery by following these steps.
    • Pull the plastic cover down (indicated by the arrow on the cover) and then swing it upwards to reveal the battery compartment.
    • The battery can now be removed by pulling it.
  3. Sony Vaio PCG-F420 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
  4. Sony Vaio PCG-F420 Keyboard Replacement: 4 단계, 이미지 1/1
    • This will unlock the cover between the keyboard and screen. Gently slide it to the right and lift up. Be sure not to pull the keyboard hard as there are still wires attached. These wires will be dealt with in the next step.
  5. Sony Vaio PCG-F420 Keyboard Replacement: 5 단계, 이미지 1/1
    • Lift up the cover and lean it against the display so it is out of the way for the rest of the process.
    • Remove the small screw above the F6 key on the keyboard. Place screw in container to ensure it wont be lost.
  6. Sony Vaio PCG-F420 Keyboard Replacement: 6 단계, 이미지 1/1
    • Find the green ribbon as indicated in the picture by the red circle. This is what connects the keyboard to the motherboard.
  7. Sony Vaio PCG-F420 Keyboard Replacement: 7 단계, 이미지 1/1
    • To unplug the ribbon cable, use a pair of tweezers to lift up the white bar near the connection to the motherboard. Only lift up the ribbon lightly to release ribbon from the motherboard.
  8. Sony Vaio PCG-F420 Keyboard Replacement: 8 단계, 이미지 1/2 Sony Vaio PCG-F420 Keyboard Replacement: 8 단계, 이미지 2/2
    • Now, you can pull on the ribbon cable and it will detach from the motherboard.
  9. Sony Vaio PCG-F420 Keyboard Replacement: 9 단계, 이미지 1/1
    • Your keyboard is now safety detached. Necessary repairs or replacements can be made from here.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Quayle
회원 가입일: 04/15/10
44 평판
안내서 2개 작성하였습니다
Cal Poly, Team 29-77, Johann Spring 2010 Cal Poly, Team 29-77, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G77
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 2,466
