주요 콘텐츠로 건너뛰기
Sony Vaio Pro 13 Bottom Cover Replacement
필요한 것
  1. Sony Vaio Pro 13 Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 1/2 Sony Vaio Pro 13 Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
    • Remove the two rubber feet at the back of the computer, these can be removed in the same way.
  2. Sony Vaio Pro 13 Bottom Cover Replacement: 2 단계, 이미지 1/2 Sony Vaio Pro 13 Bottom Cover Replacement: 2 단계, 이미지 2/2
    • Remove the four 5.6mm Philips #00 screws located at the top of the computer.
    • Remove the eight 3.6mm Philips #00 screws on the base of the computer.
  3. Sony Vaio Pro 13 Bottom Cover Replacement: 3 단계, 이미지 1/2 Sony Vaio Pro 13 Bottom Cover Replacement: 3 단계, 이미지 2/2
    • Using a plastic opening tool, pry the plastic casing away from the base of the computer, the remaining clips around the edges can be released using your hands.
    • Leave the side with the USB and audio port until last, then slide the case out and off, so the audio port doesn't get caught.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Catherine Linton
회원 가입일: 01/29/16
345 평판
안내서 1개 작성함
댓글 한 개
Hi…I have same laptop, what your advice getting the cover back on? especially near the audio and usb ports…that my hang up
thanks
chrisrai - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 23
전체 시간: 6,932
