주요 콘텐츠로 건너뛰기
Sony Vaio Pro 13 Internal Battery Replacement
필요한 것
  1. Sony Vaio Pro 13 Internal Battery Replacement, Bottom Cover: 1 단계, 이미지 1/2 Sony Vaio Pro 13 Internal Battery Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
    • Remove the two rubber feet at the back of the computer, these can be removed in the same way.
  2. Sony Vaio Pro 13 Internal Battery Replacement: 2 단계, 이미지 1/2 Sony Vaio Pro 13 Internal Battery Replacement: 2 단계, 이미지 2/2
    • Remove the four 5.6mm Philips #00 screws located at the top of the computer.
    • Remove the eight 3.6mm Philips #00 screws on the base of the computer.
  3. Sony Vaio Pro 13 Internal Battery Replacement: 3 단계, 이미지 1/2 Sony Vaio Pro 13 Internal Battery Replacement: 3 단계, 이미지 2/2
    • Using a plastic opening tool, pry the plastic casing away from the base of the computer, the remaining clips around the edges can be released using your hands.
    • Leave the side with the USB and audio port until last, then slide the case out and off, so the audio port doesn't get caught.
  4. Sony Vaio Pro 13 Internal Battery Replacement, Internal Battery: 4 단계, 이미지 1/1
    • Once the bottom cover is removed, peel away the piece of tape located near the fan and heat sink assembly.
  5. Sony Vaio Pro 13 Internal Battery Replacement: 5 단계, 이미지 1/2 Sony Vaio Pro 13 Internal Battery Replacement: 5 단계, 이미지 2/2
    • Remove the three 4.2mm Philips #0 screws located at the top of the battery.
    • Simply lift the battery away from the computer.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Alex R
회원 가입일: 01/29/16
1,005 평판
안내서 5개 작성하였습니다
댓글 한 개
I need help my Sony vaio pro 13 svp132a1cm. the power button light is dim and charging light is on but it won’t turn on I have tried everything if any one can help that will be great
Hasnain - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 21
30일 전: 80
전체 시간: 25,283
