주요 콘텐츠로 건너뛰기
Sony Vaio Pro 13 Memory Card Reader/Writer Replacement
필요한 것
  1. Sony Vaio Pro 13 Memory Card Reader/Writer Replacement, Bottom Cover: 1 단계, 이미지 1/2 Sony Vaio Pro 13 Memory Card Reader/Writer Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
    • Remove the two rubber feet at the back of the computer, these can be removed in the same way.
  2. Sony Vaio Pro 13 Memory Card Reader/Writer Replacement: 2 단계, 이미지 1/2 Sony Vaio Pro 13 Memory Card Reader/Writer Replacement: 2 단계, 이미지 2/2
    • Remove the four 5.6mm Philips #00 screws located at the top of the computer.
    • Remove the eight 3.6mm Philips #00 screws on the base of the computer.
  3. Sony Vaio Pro 13 Memory Card Reader/Writer Replacement: 3 단계, 이미지 1/2 Sony Vaio Pro 13 Memory Card Reader/Writer Replacement: 3 단계, 이미지 2/2
    • Using a plastic opening tool, pry the plastic casing away from the base of the computer, the remaining clips around the edges can be released using your hands.
    • Leave the side with the USB and audio port until last, then slide the case out and off, so the audio port doesn't get caught.
  4. Sony Vaio Pro 13 Memory Card Reader/Writer Replacement, Memory Card Reader/Writer: 4 단계, 이미지 1/1
    • Gently lift the small, black piece of tape located near the fan.
  5. Sony Vaio Pro 13 Memory Card Reader/Writer Replacement: 5 단계, 이미지 1/2 Sony Vaio Pro 13 Memory Card Reader/Writer Replacement: 5 단계, 이미지 2/2
    • Remove the three 4.2mm Philips #0 screws located at the top of the battery.
    • Simply lift the battery away from the computer.
  6. Sony Vaio Pro 13 Memory Card Reader/Writer Replacement: 6 단계, 이미지 1/2 Sony Vaio Pro 13 Memory Card Reader/Writer Replacement: 6 단계, 이미지 2/2
    • Using the flat end of the spudger, pry the edge of the ribbon wire on top of the memory card so it is loose enough to detach from the memory card.
  7. Sony Vaio Pro 13 Memory Card Reader/Writer Replacement: 7 단계, 이미지 1/3 Sony Vaio Pro 13 Memory Card Reader/Writer Replacement: 7 단계, 이미지 2/3 Sony Vaio Pro 13 Memory Card Reader/Writer Replacement: 7 단계, 이미지 3/3
    • Lift up the small, square, black piece of tape that covers the screw on the memory card.
    • Using the philips head 00, unscrew the screw holding the memory card in place.
    • Once the screw is out, the memory card should lift up easily.
결론
Alex R
회원 가입일: 01/29/16
1,005 평판
안내서 5개 작성하였습니다
댓글 한 개
Hey Alex!
Do you know if the fan is the same for the Sony Viao Pro 11 as the one for the Viao Pro 13?.
I can only see info for the fan for the 13.
Thanks!..
Raul Eduardo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 11
전체 시간: 2,031
