주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Vaio SVE111B11L Screen Replacement
필요한 것
  1. Sony Vaio SVE111B11L  Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Sony Vaio SVE111B11L  Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L  Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L  Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Push the latches towards each other and lift the battery to remove it.
  4. Sony Vaio SVE111B11L  Screen Replacement, Keyboard Assembly: 4 단계, 이미지 1개 중 1개
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
  5. Sony Vaio SVE111B11L  Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Sony Vaio SVE111B11L  Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
  7. Sony Vaio SVE111B11L  Screen Replacement: 7 단계, 이미지 3개 중 1개 Sony Vaio SVE111B11L  Screen Replacement: 7 단계, 이미지 3개 중 2개 Sony Vaio SVE111B11L  Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
  8. Sony Vaio SVE111B11L  Screen Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
    • Remove charging adaptor. Some charge may still be in the battery or computer.
    • DO NOT touch connectors or copper yellow connector.
    • Take the covers on the bottom of the laptop off.
  9. Sony Vaio SVE111B11L  Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Locate and remove the screws holding the motherboard down.
    • Screws: L 4.6mm X D 1.85mm
  10. Sony Vaio SVE111B11L  Screen Replacement: 10 단계, 이미지 3개 중 1개 Sony Vaio SVE111B11L  Screen Replacement: 10 단계, 이미지 3개 중 2개 Sony Vaio SVE111B11L  Screen Replacement: 10 단계, 이미지 3개 중 3개
    • Locate the wires and connectors and remove them from the motherboard.
  11. Sony Vaio SVE111B11L  Screen Replacement: 11 단계, 이미지 2개 중 1개 Sony Vaio SVE111B11L  Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Lift the mother board out and safely put it to the side.
  12. Sony Vaio SVE111B11L  Screen Replacement, Screen: 12 단계, 이미지 2개 중 1개 Sony Vaio SVE111B11L  Screen Replacement, Screen: 12 단계, 이미지 2개 중 2개
    • Remove charging adaptor and battery. Some charge may still be in the battery or computer.
    • Locate screws. L 3.35mm X D 1.8mm
    • Remove Screws.
    • Lay the screen on a hard flat surface.
    • Remove hinges and wires for ease of removal.
  13. Sony Vaio SVE111B11L  Screen Replacement: 13 단계, 이미지 1개 중 1개
    • Gently remove the screen cover.
    • Be careful of the camera at the top of the screen.
    • Be careful of the seal tape between the cover and the screen.
  14. Sony Vaio SVE111B11L  Screen Replacement: 14 단계, 이미지 3개 중 1개 Sony Vaio SVE111B11L  Screen Replacement: 14 단계, 이미지 3개 중 2개 Sony Vaio SVE111B11L  Screen Replacement: 14 단계, 이미지 3개 중 3개
    • Locate the wires and connectors.
    • Unplug the wires from the connectors.
    • Be careful of the yellow tape around the connection.
  15. Sony Vaio SVE111B11L  Screen Replacement: 15 단계, 이미지 2개 중 1개 Sony Vaio SVE111B11L  Screen Replacement: 15 단계, 이미지 2개 중 2개
    • Gently lift the screen assembly up and out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
John Noll
회원 가입일: 09/29/16
819 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 52
전체 시간: 1,617
